LabWindows/CVI
Probem with CAN card on my Desktop
Hi Anil,
There are only a few more things we can recommend from here. Verify that you have the same NI-CAN version installed on the laptop this card works on and your desktop. If you can, try to use a different PCMCIA-PCI adapter.
If that card is working in the laptop with no problems, then the NI-CAN card is just fine. There is probably just some small problem with how that PCMCIA adapter you're using is interfacing with the CAN card. If that's the case, there's not much we can do about it. You may want to contact the manufacturer of the adapter you're using and see if they have any recommendations.
Sorry we don't have much more information for you on this. It's just a little out of our hands if the card works fine in a laptop.
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
Message 11 of 12
(867 Views)
Hello Matt
I have tried your alternative. Its working on laptop and on another desktop straight away. Thank a lot for providing the alternatives.
Aks
Message 12 of 12
(853 Views)
