LabWindows/CVI
Probem with CAN card on my Desktop
Hi to all
I am working on CAN. For this, I have got PCIMCIA adaptor on my Desktop. So far, everything is OK. But, the CAN card is NOT being detected on my desktop.
I am working on Windows XP. Is there anything related to this. Pls do suggest, if anyone has experienced similar problem earllier. Pls make sure you post your reply at the earliest. Thanks in advance.
Anil Srivatsav
Message 1 of 12
(4,421 Views)
Hi Anil,
Does this pcmcia card work in a laptop? Are you able to have other cards work in this pcmcia coverter? You may be having problems with the adapter.
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
Message 2 of 12
(4,396 Views)
Thanks for the reply. But, the adaptor cum CAN card is straight away working on Laptop. And also on other desktops with Win 98/2000. As far as we have observed, the adaptor is working well and so is the CAN card.
Anil
Message 3 of 12
(4,384 Views)
The following Knowledge Base documents your issue.
Problems with CAN card in PCMCIA adapter
Hope this helps.
Matt S.
Message 4 of 12
(4,370 Views)
The information is really good. I will try installing Win 2000 and will update progress, if any. Thank you
Message 5 of 12
(4,364 Views)
Let us know what you find out. With Win 2K you should see fewer problems with this setup.
Good Luck!
-Matt S.
Message 6 of 12
(4,348 Views)
Hi.
FYI:
I clicked on the "PCMCIA Homepage" link on the Knowledge Base page, and found it was broken. It should take you here.
Colin.
Message 7 of 12
(4,345 Views)
I have installed Win2k. The CAN card is detected but I am getting error messges. The txt file is attached. Pls let me know recommendations, if any. Thank you
Anil Srivatsav
Message 8 of 12
(4,335 Views)
Thanks for the heads up Colin.
I'll try to get that link taken care of.
Matt S.
Message 9 of 12
(4,316 Views)
HI all
I have now installed Win XP back. And this time, CAN card is being detected. But, am still getting Interrupt Conflict error, though Win 2k/XP show that there are no conflicts. Have tried alternative resources as well. Am not sure if System configuration has anything to do with it. Anyways, my PC is Pentium 4, 2.8 GHz with 512MB of RAM and right now i am working on Win XP. Anyother alternatives pls.
Anil Srivatsav
Message 10 of 12
(4,303 Views)
