LabWindows/CVI
Problem Reading Text File
CVI programmer for many years, but it's been a while. Trying to read in a text file that comes up fine in say NotePad. The first line of text in the file is:
All temperatures in °F.
If I use the scan function, say:
static char  cdum[2048];
ScanFile (DataFile, "%s>%s", cdum); I get these results:
cdum[0] is -2
cdum[1] is 65 (which is the ASCII "A" character)
The rest of cdum is all zeros.
In a hex editor in decimal display grouped by bytes, the line is:
255 254 65 0 108 0 108 0 32 0 116 0 101 0 109 0 112 0 ... such that the display looks like
ybA.l.l. .t.e.m.p.e.r.a.t.u.r.e.s. .i.n. .°.F...
So I get that the Scan function is seeing the start character, then pulling the 65 out and putting it into the cdum[1] location, then hits the 0 character and exits the Scan function like it found an end-of-line. Trying to read in the entire line and subsequent data line which is float data, but doesn't matter, I can figure that our after I get over the initial problem above.
Can someone help me with this? I have no problem reading in regular text files, but this one is like it's grouped in words rather than bytes. Have tried a bunch of different Scan function source and target modifiers [xt0, w#, etc] but nothing seems to be working.
Data file attached.
Thanks -
Scott
(5,790 Views)
Accepted by scottrod
I have downloaded your file, it opened in Excel due to its extension and the settings on my computer. I then wanted to save it as a regular text file to see it in Notepad and to read it with a simple C program. When doing so, Excel told me: Some features in your workbook might be lost if you save it in Unicode text.
This is compatible with your observation of 16 bit data.
Unfortunately LabWindows/CVI does not support the Unicode character set and library functions operate on 8 bit characters only.
So i would suggest to convert your file to 8 bit characters; you also may support the quest for Unicode support in CVI here
(5,780 Views)
Thanks Wolfgang. I was unfamiliar with the Unicode set, but it makes sense now.
Will find a workaround.
(5,776 Views)
