LabWindows/CVI
Problem of using FileSelectPopup()
I have a code phase which call the Windows' API:
while (TRUE)
   WaitForSingleObject(audioEventHandle, INFINITE);
Today , I find a problem: using the FileSelectPopup() to show a file select dialog, if do a right click mouse by careless, the execuating will jump into  this while loop and block at the  WaitForSingleObject(). I think  there is a mouse right click event captured by the Windows system, I'd like to know is there any way to escape it?
David
(4,907 Views)
David_Lee,
The information you provided is still rather very little. Please also provide the context in which the two sequences are used. E.g.:
  1. Is the while-loop located in a control-callback or panel-callback? Where is this exactly?
  2. In which context do you use FileSelectPopup()?
A code snippet which reproduces the problem would be very helpful.
Also, have you tried browsing through other forum posts, just in case somebody else asked a similar question? This might prove useful:
http://forums.ni.com/t5/forums/searchpage/tab/message?q=fileselectpopup
Regards!
- Johannes
(4,836 Views)
