LabWindows/CVI
Problem with SQL -> LIKE Statement
Hi I have a few Problem with an SQL Statement that I use in ni-SQL-toolkit:
SQL = "SELECT C_Profile FROM PROFILE_TAB WHERE C_Profile LIKE '*SCT*' ORDER BY C_Profile ASC"
When I try to use in Access it works fine, I get records back... If I use trough SQL-Toolkit I dont get any records.
the other part of the code:
DBHandle = DB_Connect(DB);
DBAllowFetchAnyDirection (DBHandle,1);
SQLHandle = DBActivateSQL (DBHandle, SQL_SELECT);
if(SQLHandle == 0) goto Error;
numCols = DBNumberOfColumns (SQLHandle);
numRecs = DBNumberOfRecords (SQLHandle);
numRecs is always 0.
Any Idea ? thanks
(3,186 Views)
Try:
SQL = "SELECT C_Profile FROM PROFILE_TAB WHERE C_Profile LIKE '%SCT%' ORDER BY C_Profile ASC"
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,186 Views)
