Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
dos window appears at startup
guyroy
Member
06-17-2004
11:43 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
A dos window appears when a released executable is started. The program starts from C:\WINDOWS\SYSTEM\conagent.exe
Some otherreleased executable DO NOT have that window.
How can I get rid of this DOS window??
0
Kudos
Message
1
of 3
(3,294 Views)
Reply
Re: dos window appears at startup
Jattie
Member
06-17-2004
11:48 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Did you perhaps check on the create terminal application checkbox in the build application dialog box?
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
1
Kudo
Message
2
of 3
(3,294 Views)
Reply
guyroy
Member
Author
06-18-2004
09:27 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Good answer. In the 'Build' drop-down menu under 'Target Settings...' the 'Create Console Application' box was checked.
Thank You Jattie
0
Kudos
Message
3
of 3
(3,294 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
