dos window appears at startup
A dos window appears when a released executable is started. The program starts from C:\WINDOWS\SYSTEM\conagent.exe
Some otherreleased executable DO NOT have that window.
How can I get rid of this DOS window??
(3,166 Views)
Did you perhaps check on the create terminal application checkbox in the build application dialog box?
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,166 Views)
Good answer. In the 'Build' drop-down menu under 'Target Settings...' the 'Create Console Application' box was checked.
Thank You Jattie
(3,166 Views)
