Problem with table editor
Hi again,
in the UI editor, I have set up a table with 7 columns, including a label row. Now I would like to have column 3 to be the rightmost column; accordingly I selected column 3, pressed 'Cut Column', and indeed the column is gone. However, I can not make it to paste it in the correct place: if I select column 6, or 7, or 8, and then press the 'Paste Column' button, the former column 3 gets pasted, but never in the last column, but in the last but one...
What's wrong?
Wolfgang
(3,426 Views)
Hello Wolfgang,
you are right, it allways pastes the cut column before the selected one - but that should not be a problem at all.
To solve the problem just add a column at the end, select the newly created one and paste the column. After that you can delete the empty column again.
Kind Regards,
Johannes Graeper
(3,419 Views)
Accepted by Wolfgang
Hello Johannes,
I solved 'the problem' slightly different by cutting and repasting the rightmost column 🙂 Thanks anyway!
(3,415 Views)
