03-04-2008 02:22 PM
03-04-2008 03:58 PM
03-05-2008 12:17 PM
03-05-2008 02:43 PM
Yes it is version 8.1.1
I saw the other thread that relates to this. I am not sure that I have the same problem. I do have controls on top of the strip chart. I will move them to see what happens. I just have not yet done that.
03-14-2008 11:16 AM
I moved the other controls to NOT be on top of the strip chart and that fixed the problem !
This does not explain why one of my applications had this problem while another did not. (They shared the uir file)
But this fixes the problem and I am moving on.
03-14-2008 11:31 AM
Thanks for the update, John.
It's definitely unexpected that you ran into this bug in CVI 8.1.1. My guess is that even though you're using the CVI 8.1.1 ADE, you might have the CVI 8.5 runtime engine installed (c:\windows\system32\cvirte.dll) and that would explain it. Or maybe it really is a different issue than the one I was thinking of.
But since you've already worked around that problem, then I guess the situation is resolved.
Luis
03-14-2008 12:31 PM
