LabWindows/CVI
Progressbar usage
Hi, actually I´m working in a project that includes a microsoft progressbar activex. Is the first time that I´m use an activex in a LabWindows project. I need help about set the value of progressbar. I try this with SetCtrlAttribute function but this don´t work. Please If any have information about using this activex with LabWindows help me. Thanks.
(4,858 Views)
I cannot help you with the activex control, but have you considered using the CVI progress dialogue instead of the activex one? Create-, Update- and DiscardProgressDialogue functions can be found in the Programmer's toolbox that comes with CVI: it's located in <cvi>\toolslib\toolbox directory; the instrument is named toolbox.fp
(4,840 Views)
you should use the special instrument functions to control this progress bar.
Right-click the Progress Bar in your uir file and select "Generate ActiveX Control Driver" from the popup menu. After you completed the wizard, the "Microsoft Windows Common Controls" Instrument is available in the Instrument Menu. You can see a lot of folders in this instrument. IProgressBar is one of them. You should use the function "MSComctlLib_IProgressBarSetValue"  to set the value of the progress bar.
If you have any more questions, please ask.
Success,
Wim
PS: to be honest, I would go for Roberto's suggestion Smiley Wink
(4,810 Views)
