Project link error with library build with Visual C++ comiler with option /MD
my LabWindows/CVI project includes a  library that was according to the supplier build using Visual C++ compiler with option /MD, so that both multithread- and DLL-specific versions of the run-time routines are selected from the standard .h files. This option also causes the Visual C++ compiler to place the library name MSVCRT.lib into the .obj file. (see http://msdn2.microsoft.com/en-us/library/2kzt1wy3(VS.71).aspx for further details). The build of my application aborts with the following linker errors:
 5 Project link errors
  Undefined symbol '__imp__exit' referenced in "thirdparty.lib".
  Undefined symbol '__imp____p__environ' referenced in "thirdparty.lib".
  Undefined symbol '_putenv' referenced in "thirdparty.lib".
  Undefined symbol '_access' referenced in "thirdparty.lib".
  Undefined symbol '__imp___iob' referenced in "thirdparty.lib", "thirdparty.lib", and "thirdparty.lib".
In the suppliers documentation for the library it is said that the linker option /NODEFAULTLIB:"LIBCD.LIB" must be set when the application is build with the Visual C++ compiler. I don't know whether this would solve the problem in LabWindows, anyway it is not possible to set any linker options in LabWindows(?) I found a mas of similar linker problems like the above in the web (search for __imp__exit), where it points out that it depends on linker settings, which LabWindows seem not to support.
I've tried with other options (compatibility to Borland C++ and corresponding library version, changing calling conventions etc.) without success.
Is there anybody out there who experienced similar problems or may have a solution for me?
Thanks in advance, Walter
(3,665 Views)
Hello Walter,
you could try to generate a DLL import library in cvi itself. Open your .h-file  in CVI go to options
and then hit  "Generate DLL Import Library". Using this lib possibly fixes the problem.
regards
Marco Brauner NIG
(3,603 Views)
Hello, thank you very much for your reply! I tried this option and actually it helps "some", that means instead 5 linking errors I got only one undefined symbol of a function my code is calling from the library. I guess there is a dll which I do not know which includes the missing function.
Anyway, I tried with LabWindows/CVI version 8.1 and surprisingly the linker errors disappeared!
Hello NI, what has changed in your library? I'm using LabWindows/CVI 7.1.1 where the linker error has occured.
regards, W. Lenz
(3,570 Views)
