Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
RS-232 OpenComConfig error -2
silvlan
Member
09-30-2002
06:48 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi there. Running fp OpenComConfig interactively, I always get error -2 (invalid port number) on WinNT, with COM1 or COM2. Same thing happens running serial.prj on example of CVI. Thanks for any help.
0
Kudos
Message
1
of 2
(3,538 Views)
Reply
Re: RS-232 OpenComConfig error -2
DiegoF
NI Employee (retired)
10-01-2002
11:18 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The first thing to check is if the serial ports are working. You can use Hyper terminal to do a loop back test on the ports.
The following tutorial has information that you might find useful.
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/c553228fd78a7add862568f9006e9129?OpenDocument
DiegoF.
National instruments.
0
Kudos
Message
2
of 2
(3,538 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
