LabWindows/CVI
Using viLogger within CVI
I'm setting up a measurement chain with viLogger (1.0.1) and would like to use it from CVI (5.5). I found the corresponding functions in the Library tree but no reference information.
Is there a sample code available?
(3,734 Views)
Some examples are there in
C:\Program Files\National Instruments\MeasurementStudio\CVI\samples\cvilog
Sincerely,
Sastry V
(3,734 Views)
Hello
I'm using CVI 5.5 and have some problems with opening the uir-files of the samples. Despite this fact I created a debugging exe and got an error when trying to run (entry point of _mbsspn not found in cvirte.dll).
Do I need to upgrade to CVI 6.x?
Sincerely
H.P. Bertschinger
(3,734 Views)
Yes to run VI logger in CVI, CVI 6 is needed.
You can take a look at the readme file.
ReadMe
Sincerely,
Sastry V.
(3,734 Views)
