LabWindows/CVI
Random Crashes of CVI 2020
Hi guys,
I recently switched from CVI2017 to the newst version of CVI (20.0.0).
My software now randomly crashes while in idle (seems to be random) with the error:
Unrecoverable Internal Error at 0023:622A8B1B.
LabWindows/CVI will be aborted.
I never had this issue with CVI2017. My used OS is Windows 11.
Any ideas how to fix this?
(1,211 Views)
Did you check the Windows Event Viewer?
The crash explanations there might shed some light on the issue.
S. Eren BALCI
IMESTEK
(1,189 Views)
Anything useful here?
- System
- Provider
      [ Name] CVI
- EventID 0
      [ Qualifiers] 40960
  Version 0
  Level 2
  Task 0
  Opcode 0
  Keywords 0x80000000000000
- TimeCreated
      [ SystemTime] 2025-05-05T13:25:30.9879897Z
  EventRecordID 135318
  Correlation
- Execution
      [ ProcessID] 9156
      [ ThreadID] 0
  Channel Application
  Computer
  Security
- EventData
[15:25:30.986] [FATAL] [GeneralSignalHandler] [.\source\jeff\i386\except.c:179] General Protection
(1,176 Views)
I was waiting something like this.
It can also be in the Application sub-group of the tree on the left.
S. Eren BALCI
IMESTEK
(1,161 Views)
Thats where I checked. But since my OS is in german, I decided to copy the "Details"-menu, not the "General".
In "General", the same information is given. Only in the box above is a german description that is not in "Details", but it is completely useless, here a translation with DeepL:
"The description for the event ID “0” from the source “CVI” was not found. Either the component that triggers this event is not installed on the local computer or the installation is damaged. You can install or repair the component on the local computer.
If the event occurred on another computer, the display information had to be saved with the event.
The following information was saved with the event:
The message resource is available, but the message was not found in the message table"
(1,145 Views)
@tsmc wrote:
Hi guys,
We are using 2017 as well, and have have been working on migrating away from LabWindows. We did consider "one last update" to 2020 to get official Windows 11 support, though I see that requires some patches since the stock 2020 was not listed as Win 11 compatible. (Neither is 2017, but what we use seems to work except for some second-monitor graphical glitches in the IDE.)
What patch level do you have your 2020 at?
(1,089 Views)
It might be related to compatibility issues between CVI 20.0.0 and certain Windows 11 updates. Try running the software in compatibility mode for Windows 10 or check if any background processes are interfering. You may also want to monitor arrest update NJ resources when debugging system logs for context, as they sometimes highlight activity patterns tied to system instability. Let us know if any specific DLLs are mentioned in the crash log.
(1,041 Views)
