Read a file between two lines
Can you tell me if, thank's to a function, we can read between two lines ?
For example, I have one file in.txt, it has 10 lines, and, I want to write what we have between lines 4 and 8 in an other file out.txt.
Thank's for your time
(3,405 Views)
Accepted by Zerged
There isn't a native function that performs what you want but you can easily write one by yourself.
Something like this (pseudocode):
Open file for input (OpenFile)
Open file for output (OpenFile)
Read all lines one-by-one (ReadLine)
  Copy desired lines to oputput file (WriteLine)
Close input file (CloseFile)
Close output file (CloseFile)
Do not forget to add a proper error checking strategy to deal with I/O errors.
(3,395 Views)
Accepted by Zerged
answer is given here
(3,394 Views)
Yesss! That's the problem when posting the same question twice! Smiley Sad
In the future please do not repeat this: always post a single question in the international board, or post directly to the French board if you prefer your native language
(3,387 Views)
Thank's for your answers, I have found the solution ! 🙂
Ok I'll do not repeat this !
(3,376 Views)
