LabWindows/CVI
Read function for analog output
Hi I am new to programming with NI DAQ. I am using NI USB-6003 with python. First I am trying with C.
I am using the WriteAnalogScalarF64() to write on the analog output. But what is the command to read what value is being output?
ReadAnalogF64() gives error, so I think it only applies to the analog inputs. What I need is a function that gives me what is the value set at analog output.
Thanks.
(3,303 Views)
Accepted by mdaliaamir
If I am not mistaken, I don't believe there is a function to read from the analog output. It is likely better to create a loop-back connection and hook up the analog output to the analog input of another pin on the same NI USB-6003 and read the analog input pin with the ReadAnalogF64 function.
Vincent
(3,287 Views)
Thanks a lot, VincentTang! I also think you are right. So this is what I have done.
(3,266 Views)
