LabWindows/CVI
Reading data from Text file and accessing Lines
Naqvi_hassan wrote:
Hi , my code is this , so i just put the example data in the array and want to plot but  this code is not plotting the Negative Values.
int CVICALLBACK Get (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
 unsigned int f[8];
 f[0]=10;
 f[1]=0;
 f[2]=20;
 f[3]=0;
 f[4]=0;
 f[5]=-10;
 f[6]=0;
 f[7]=10;
 switch (event)
  case EVENT_COMMIT:
    PlotY (panelHandle, PANEL_GRAPH, f, 8, VAL_UNSIGNED_INTEGER, VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_RED);
     SetAxisScalingMode (panelHandle, PANEL_GRAPH, VAL_LEFT_YAXIS, VAL_MANUAL, -60.0, 60.0);
   break;
  case EVENT_RIGHT_CLICK:
   break;
 return 0;
An unsigned array cannot hold negative values!
Message 11 of 12
(1,129 Views)
oh   mannnnnnnnnnnn (uffffffff) , thank you very much  ,  waste your time bcoz of this stupid mistake.
Message 12 of 12
(1,121 Views)
