Showing results forĀ
Search instead forĀ
Did you mean:Ā
Real Scale Graph
How can i make my graph use a real scale..?
i mean the sides x,y are 1:1 and the whole graph is in real (scaled though) dimensions..
The problem is that i'm using autoscale. so when Xaxis changes the yaxis is not, causing (e.g) a rectangle seem like a square..
Thanks in advance..
(3,976 Views)
There is no built-in function to sync x and y axis of a graph. You could possibly use GetAxisScalingMode after each plot  function and update accordingly the other axis if the min/max have changed. Or you could disable autoscaling and manually rescale the diagram while plotting depending on the plot dimensions.
(3,968 Views)
To get you started, here is some code that I have used to set a 1:1 aspect ratio for a graph:
// Reset the aspect ratio of a graph - which may have been autoscaled - to 1:1
// Assume panel handle is held in 'pMain' and the graph control is 'MAIN_GRAPH'.
 double xmin, xmax, ymin, ymax;
 int dum1, dum2;
 double ratio1;
 double ratio2;
 // Find the current axis ranges
 GetAxisScalingMode(pMain,MAIN_GRAPH,VAL_BOTTOM_XAXIS,&dum1,&xmin,&xmax);
 GetAxisScalingMode(pMain,MAIN_GRAPH,VAL_LEFT_YAXIS,&dum1,&ymin,&ymax);
 // Add a bit to the graph to ensure there is white space around the plots
 xmax+=1.0;
 ymax+=1.0;
 xmin-=1.0;
 ymin-=1.0;
 // Now work out the ratio of x axis to y axis
 ratio1 = (xmax-xmin)/(ymax-ymin);
 // Now find out how big the plot area of the graph is in X and Y directions
 GetCtrlAttribute(pMain,MAIN_GRAPH,ATTR_PLOT_AREA_WIDTH,&dum1);
 GetCtrlAttribute(pMain,MAIN_GRAPH,ATTR_PLOT_AREA_HEIGHT,&dum2);
 ratio2 = ((double)dum1)/((double)dum2);
 // Need to make ratio1 = ratio2 by adjusting ranges
 if (ratio1<ratio2)
  // Need to expand X area
  double expandval = 0.5*((ratio2/ratio1)-1.0)*(xmax-xmin);
  xmin -= expandval;
  xmax += expandval;
 else
  // Need to expand Y area
  double expandval = 0.5*((ratio1/ratio2)-1.0)*(ymax-ymin);
  ymin -= expandval;
  ymax += expandval;
 // Finally, set the new axis ranges
 SetAxisScalingMode(pMain,MAIN_GRAPH,VAL_BOTTOM_XAXIS,VAL_MANUAL,xmin,xmax);
 SetAxisScalingMode(pMain,MAIN_GRAPH,VAL_LEFT_YAXIS,VAL_MANUAL,ymin,ymax);
Martin
Certified CVI Developer
(3,959 Views)
thanks msaxon but it looks like that your routine didn't work for me as i expected.. i want to be able to use autoscale for both axis and have a 1:1 ratio.. also i've noticed that it wasn't exactly 1:1.. (maybe i have some attributes that you didn't have..) anyway i found the solution..
void autoscale(int control)
int dum1, dum2;
double ratio1;
double ratio2;
SetAxisScalingMode (panel_handle, control, VAL_XAXIS, VAL_AUTOSCALE, 1,2);//force graph to auto fit the plot.. (min,max value is random.. maybe there's a better way to do it.. it works though..)
SetAxisScalingMode (panel_handle, control, VAL_LEFT_YAXIS,VAL_AUTOSCALE, 1, 2);
GetAxisRange (panel_handle, control, &dum1, &xmin, &xmax, &dum2, &ymin,&ymax);
GetCtrlAttribute(panel_handle,control,ATTR_PLOT_AREA_WIDTH,&dum1);
GetCtrlAttribute(panel_handle,control,ATTR_PLOT_AREA_HEIGHT,&dum2);
if (ratio1>ratio2)
SetAxisScalingMode (panel_handle, control, VAL_LEFT_YAXIS, VAL_MANUAL, xmin/ratio2,xmax/ratio2); //scale Yaxis according to Xaxis..
else
SetAxisScalingMode (panel_handle, control, VAL_XAXIS, VAL_MANUAL, ymin*ratio2,ymax*ratio2);//Scale Xaxis according to Yaxis
Message Edited by karpa on 06-24-2008 05:31 AM
(3,940 Views)
