LabWindows/CVI
Remote debugger gives error about not supporting this version
I have LabWindows/CVI 8.0.1 (356) on a Windows 7 machine and I'm trying to remotely debug a product on a Windows XP machine.  The product is a DLL called by TestStand sequences.  TestStand is version 2.0.1f1.  When trying to connect, I receive the following error message ( see attachment ) after the debugger machine sees TestStand was launched on the debugee machine.  What does this mean?  Thanks.
-G-
(3,227 Views)
Hi Grasshopper,
There is a document which goes over the LabWindows/CVI remote debugging set up in detail.  You can locate this document at the following URL: http://www.ni.com/white-paper/3384/en .  It is possible there is a configuration step you are missing.
In addition to looking over that document, can you give me more information about your system?  I would specifically like to know what software is installed on each computer.  I would like to know the versions of the software installed on each computer.
Thank you,
Daniel Dorroh
(3,211 Views)
I've been through the link you sent and I think I'm doing everything as stated.  Attached are the software lists.
-G-
(3,204 Views)
Hi Grasshopper,
This problem is possibly occurring because your LabWindows/CVI Run-Time Engine is newer than your version of LabWindows/CVI Development System.  Please refer to the following forum thread which mentions a similar problem with remote debugging:  http://forums.ni.com/t5/LabWindows-CVI/Remote-Debug-problem-with-CVI-Runtime-Versions/m-p/2067462 .
To correct this problem, you must make the version of your Run-Time Engine (RTE) the same as or earlier than the version of your Development System.  You can either do this by upgrading LabWindows/CVI to a newer version, or by uninstalling the RTE on your debugger/debugee, and then installing the RTE corresponding to your Development System on both machines.
Please let me know after completing this step whether you encounter any further errors.
Warm Regards,
Daniel Dorroh
(3,184 Views)
