‎10-24-2012 05:14 PM
Tengo un problema al crear el ejecutable en CVI 8.0.1 . En la ayuda sale un mensaje de que si algun archivo aparece en rojo es porque ha sido movido o borrado, en mi caso es el propio ejecutable el que me aparece n rojo. adjunto un pantallazo para mostrar el problema. a ver si me pueden echar una mano. gracias
‎10-25-2012 07:21 PM
This is probably because you have not built a Release configuration yet. The Distribution will only include the release executable, so if you have not built one yet, it will display as red. When you build the distribution, it will display a message indicating that your project needs to be rebuilt; this indicates that your Release build is not up to date.
‎10-25-2012 09:44 PM
Thank you Biel,
Now is not in red, but I can find it nowhere!, even I selected launch after being created and nothing happened
‎10-29-2012 11:57 AM
What are you unable to find? The distribution you built, or the application executable? Is this on the target system or the development system that you are referring to?
The distribution will be found in <project directory>/cvidistkit.<application name>/Volume.
The application itself is found at the location specified by Build >> Target Settings >> Application file.
‎10-29-2012 01:21 PM
you're absolutely right! thanks Biel
