Remote debugging in CVI 8.5.1
I rebuilt a debug version of the executable and copied the .exe and .cdb to
the remote target (a PC). I started up the Configure Remote Debug application on
the target. When asked I started the .exe. I get the error "The debugging
information file for this file is out of date. <EXE NAME> You will be
unable to debug this dll/exe. Would you like to terminate.
Another engineer running 8.5.0 is able to remote debug on the machine.
(5,415 Views)
Hey Scott,
Does the target machine have CVI installed on it? And can the other engineer rebuild and successfully debug on the machine with the same exe ?
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(5,385 Views)
The target machine doesn't have the CVI development library installed, just the run time engine.
I'm pretty sure that he rebuilt it with his version (8.5.0) before trying the remote debug.
We both rebuilt debug versions and copied them over to the target PC before doing the debug.
(5,365 Views)
Okay, after what step in this process http://zone.ni.com/devzone/cda/tut/p/id/3384 are you getting the error? Also after you dismiss the error, what happens? Make sure that since there are two of you debugging remotely, that you're not trying to do it at the same time, or that the remote machine isn't connected to the wrong debugging host. Based on your error message i doubt that would be the cause, but you never know. Since I would assume that both of you are on the same network, and you're using the same version of CVI there should be no reason this isn't working. Get back to me with the info I asked for and I can we can do some more digging.
(5,353 Views)
The error happens when I press Shift+F5 or Debug Project and then launch the executable
If I choose Terminate then the debugging and the executable stops
If I let it run, the .exe runs but I can't debug
The only difference is that I'm using 8.5.1 and he's using 8.5.0
We are not trying to debug at the same time.
(5,306 Views)
Scott, have you tried deleting your debugging file completely, and re-creating it, then re-deploying?
(5,303 Views)
Accepted by Scott
Found the problem. I am compiling the program off of a network drive, T:. I had an old version of the .exe and .cdb on a directory on my computer C:
When I deleted the local copy on C:, then it started working. I'm not sure why it was looking on my C: drive since my project directory is T:
(5,218 Views)
