LabWindows/CVI
Remove Close Control
is there a way to remove/invisible the close icon in the upper right of a CVI-Panel?
By the way the system bar with its task icon and panel name should be visible.
greetings
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,769 Views)
Hello Jürgen,
You can't remove it completely, but you can disable it by setting the ATTR_CLOSE_ITEM_VISIBLE panel attribute to 0.
Luis
(4,758 Views)
Hi Luis,
That are bad new's.
Seems i have to play with SDK to figure out a crazy function
Greetings
juergen
--Signature--
(4,745 Views)
You could try using SetPanelAttribute to set ATTR_TITLEBAR_VISIBLE to 0.  That will get rid of the whole titlebar, including the close control.
(4,728 Views)
Hi tstanley,
That might be a solution, but i want to use it because i need the titlebar caption and the icon.
I have played with SDK. I am able to the remove the close from icon-menu a dimm the x-Button. But thats not what i need.
//HWND hWnd;
//GetPanelAttribute (m_hPanel, ATTR_SYSTEM_WINDOW_HANDLE, (int*) &hWnd);
//HMENU hMenu = GetSystemMenu(hWnd, FALSE);
//DeleteMenu(hMenu,SC_CLOSE,MF_BYPOSITION);
Maybe there is an other SDK function doing this.
Greetings
Juergen
--Signature--
(4,711 Views)
Hello j_dodek,
you can use the panel attribute "ATTR_SYSTEM_MENU_VISIBLE". Then you see the titlebar of the panel an the panel icon.
Greets Be-Mo
(4,672 Views)
