LabWindows/CVI
Removing old versions of CVI ?
Hello all,
On my development system, I just upgraded to 2013sp1, so I now have CVI 8.5, 2010, 2012 and 2013. I had to enlarge the partition so that I could install 2013 ! But I must be overlooking something obvious since I cannot find a way to uninstall the old versions. It's not in the Control panel / Software Add, it's not in the NI License Manager...
Thanks.
(4,516 Views)
Accepted by gdargaud
In control panel, add/remove program there should be a Netional Instruments Software item: if you click on Change you should be promptedwith a list of annNI products installed with options to uninstall.
(4,504 Views)
D'oh !
To my defense I missed it because my system is messed up between different languages and thigs are not always sorted where I expect them...
(4,480 Views)
