Representation of chemical symbols
Hello, hello,
I'd like to show full chemical symbols in the user interface, exactly like this:
As far as I know there is no subscript/superscript for text in CVI, so it'd have to be done either:
  • graphically in a canvas, with 4 CanvasDrawText(), and then possibly converted to a BitMap for reuse.
  • directly in the UIR with 4 Text Message controls.
  • Just use ugly text like Mg12:24+2 but the chemists will weep.
Any other idea ?
(1,506 Views)
the idea of subscript/superscript in UI text is under consideration for 12 years now 🙄, and with the unofficial end of the product is not likely to be realized.... I used the second approach with several text message controls which is more effort but looks reasonable
(1,500 Views)
Yeah, I'd seen your idea suggestion, but unless HTML gets folded into CVI, I don't see how they could get it in ! No small feat, without even considering the Damocles sword hanging above CVI.
I need the chemical symbols on graphs and in tables, so I'll try the canvas/bitmap/image approach.
(1,498 Views)
Accepted by gdargaud
I've coded a small(ish) function to create a bitmap of a chemical element symbol, with options. It's available at https://gitlab.com/dargaud/ElementBitmap
(1,417 Views)
