Request SQL contains keyword "LIKE"
I want to select 'Id' from 'table' where chaine begins with 'BR' the request is like this : SELECT Id FROM table  WHERE chaine  LIKE 'BR%', it works when i run it in MS Access but when i include it in Labwindows CVI it generate an error ( unknown specifier).
I'm searching for the equivalent of the caracter % .
Note:
Hardware Environment: PC DELL  intel(R) Core(TM) 2DUO CPU
Software Environment : Labwindows CVI  2010
(4,208 Views)
Hi FENM,
I'm not sure that I completely understand what is happening - would you mind posting a screenshot or sample of the code that isn't working?
--G-IV
(4,147 Views)
Accepted by FENM
If you use sprintf to format the request, % is the format specifier ==> you must use %% in the format string to escape the format specifier (%)
sprintf (request,  "SELECT Id FROM table  WHERE chaine  LIKE 'BR%%'");
with a string parameter:
sprintf (request,  "SELECT Id FROM table  WHERE chaine  LIKE '%s%%'", "BR");
(4,124 Views)
