(Request help for a project) Save a photo with a date and time
Currently studying for a Professional Degree in Mechatronics and Robotics in France,
I have just discovered the CVI Labwindows software, during my training, I have to carry out a project.
I am asked to create a screenshot function and I have to save to a file, the photo will be named with a date and time at the time of the screenshot (Example "19/11 / 2021_15: 54.png").
So far I have succeeded with the SaveBitmapToFile function, but I do not know what to name the photo with date and time
error = SaveBitmapToFile ("c: \\ Users \\ jack \\ Desktop \\ screenshot \\ capture.png", cviBitmap);
I thank you in advance.
Regards.
Tim
(3,333 Views)
You can't give that name to your file: both slash and colon are not allowed in file names! (see this useful discussion  on that)
What you can do is to use strftime () in Ansi C library to obtain a string representation of a given date and time with separators allowed in file names. You can search for function reference in every C manual at your choice.
(3,325 Views)
is it possible to give me an example with strftime () and file name? to understand functions, because I just discovered this program
thanks
(3,120 Views)
is it possible to give me an example with DateStr() in file name? to understand functions, because I just discovered this program
(3,142 Views)
Accepted by TimStudent50
It's not difficult: DateStr () returns a string so sprintf ("%s.tst", DateStr ()); will return a correct filename.
CVI is a standard C-language programming environment: if you are new to C language you should take some time to learn the language before approaching the IDE. Or at least be sure to keep a C reference manual at hand as long as you go on developing your app. And this board cannot replace that manual!
(3,131 Views)
Hello, I just succeeded !
                   #define DATETIME_FORMAT « %Y_%m_%d-%H_%M_%S »
                   #define CHARSIZE 256
                   Char filename [CHARSIZE] ;
                   Double datetime : 0.0 ;
                   Int ret = GetCurretDateTime(&datetime) ;
                   Char datetimeStr[CHARSIZE] ;
                   Int len = FormatDateTimeString(datetime, DATETIME_FORMAT, datetimeStr, CHARSIZE) ;
                   Fmt (filename, « C:\\Users\\........\\%s.png », datetimeStr) ;
                   SaveBitmapToFile (filename, image);
(3,059 Views)
