LabWindows/CVI
Reset Most Recently Closed from CVI
How can I reset the Most Recently Closed files from the File selection menu within CVI?
Tony
(3,187 Views)
Hello Tony,
I think it is possible to do so by editing the windows register (start, run, 'regedit').
A list of closed files can be found in here under My Computer\HKEY_USERS\("some long number/code")\Software\National Instruments\CVI\7.0\ClosedFiles.
Ward Jennekens
(3,169 Views)
Hello Tony,
In additional you can clear the recently closed project list by searching for the PreviousProjects key in My Computer\HKEY_CURRENT_USER\Software\National Instruments\CVI\<cvi version>.
Also, as a side note, I would be wary about making any additional changes to the registry seeing as though this could dramatically affect the behavior of your machine.
Thanks and I hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,139 Views)
