LabWindows/CVI
Returning an array of structs from a function?
Hi all!
I had posted a few days ago about some software I was working on. It is for an API for a client. They wanted it in the CVI environment for their project. It's essencially a parser. So we are aiming to create a .h and .C file that has a function in it that can be called so they can parse a file and read each of the elements in a .csv file. Each line will be separated and placed in a variable in a struct that is an element in an array of structs.
I've developed the function. now I want to get the function to handle two arguments: an array with the filepath string stored in it, and the number of lines to read.
so it essentially was a function that had a void type.
void ParseConfigFile(char filepath[], int LinesToRead);
 I have the struct decleration defined in the header file.
I then declared:
struct TestStep TestSteps[500];
During debugging I was just able to print at the bottom of the function using a format like:
TestSteps[LineNumber].StructElement
easily.
How do i convert it into a function that can be called with the arguments shown above and return the array of structs so the user can just call:
 I hope that wasn't confusing.
Thanks in advance!
(4,850 Views)
Basically, you should be able to do something like this:
/// HIFN ReadFile
/// HIFN The function reads the data file and stores the content in an
/// HIFN array of structs for the caller
/// HIPAR file/The pathname of the file to read
/// HIPAR nrec/The number of records read from the file (returned to caller)
/// HIRET The allocated array of structs read from the file
/// HIRET It is responsibility of the caller to free the allocated memory
/// OUT nrec
myStruct *ReadFile (char *file, int *nrec)
	int	size;
	FILE	*fH = NULL;
	logRec	*xl = NULL;
// WARNING!
// Error checking must be added for all I/O operations
	// Check if file exists and calculate array size
	if (!FileExists (file, &size) || !size) {
		MessagePopup ("Read", "Either the file does not exist or there are non records to view.");
		return NULL;
	*nrec = size / sizeof (myStruct);
	// Allocate and intialize memory
	xl = malloc (*nrec * sizeof (myStruct));
	memset (xl, 0, *nrec * sizeof (myStruct));
	// Open, read and close the file
	fH = fopen (LOGF, "rb");
	fread (xl, sizeof (myStruct), *nrec, fH);
	fclose (fH);
	// That's all!
	return xl;
Please take care of freeing memory after you have finished using it.
(4,839 Views)
