LabWindows/CVI
session handle is not valid
I'm trying to read values from a Fluke 8846A Digital Multimeter, however when I run the functions to initiate the device it gives me a runtime error reading
"Timeout expired before operation completed"
Also, later when I try to configure the multipoints and minmax and try to read this data, I get the following runtime error:
"session handle is not valid "
Here is my code:
fl884x_init ("DMM1", VI_TRUE, VI_TRUE, &DMM1);  //Attempting to initialize the Digital multimeter, with a handle DMM1 (gives me the first error)
//All of these give me the same runtime error "session handle is not valid "
fl884x_ConfigureMultiPoint (DMM1, 1, 5000, FL884X_VAL_INTERVAL, 0.0);
fl884x_ConfigureMinMax (DMM1, VI_TRUE);
fl884x_Initiate (DMM1);
fl884x_ConfigureTrigger(DMM1, FL884X_VAL_IMMEDIATE, 0.0 );
fl884x_FetchMultiPoint (DMM1, 5000, 5000, &measurementData, &numberOfPoints);
fl884x_FetchMinMax (DMM1, 5000, &measurementDataMin, &measurementDataMax, &measurementDataAvg, &minMaxCount);
I imagine that if I can fix the first error, the second will be fixed as well.
Thanks in advance
(5,642 Views)
I would expect that the first parameter of the function fl884x_init (,,,) is the resource name specifying the interface and address of the device (such as GPIB::14::INSTR)
(5,633 Views)
Yes, I edited the statement where I initialize the instrument to :
fl884x_InitWithOptions ("GPIB0::2::INSTR", VI_TRUE, VI_TRUE, "Simulate=0,RangeCheck=1,QueryInstrStatus=0,Cache=1", &DMM1);
But I am still getting the same error.
Also, whenever I use the VISA test panel to run an *IDN?\n query, it gives me the same error.
(5,630 Views)
