LabWindows/CVI
SQL Find a record example
I am creating a simple database.  I am first trying to check to see if a record exists, if exists I will then update it.  if not, I will create a new record.  do simple examples exist to perform these tasks using the SQL toolkit?
(3,858 Views)
Accepted by Joncombat
This problem can be solved by creating a query that looks for the record you want to locate and update / create a new record depending on whether the query actually returned a record. The SQL toolkit can run the queries like "SELECT ... FROM... WHERE ...", after that you can check whether a record is returned with DBNumberOfRecords, getting its value with DBFetchNext.
The sample program <CVISampleFolder>\sql\simple\readtab3 can be a good starting point to elaborate your own strategy for that.
(3,833 Views)
actually this only solved half my problem.  I am able to determine if a record exists using the example.  it uses the bind command.  The example that uses the insert/update command uses the map command.  can I create a new record using the bind commands?  are there examples?
(3,823 Views)
I must admit that I normally do not update records in a database, but I see in the documentation for DBPutRecord that it can be used for this task (highlight is mine):
Places the current record in the database. You can use DBPutRecord with new records you create with DBCreateRecord or with existing records you fetched from a SELECT statement.
So as far as I can understand the procedure should be:
  1. DBActivateSQL
  2. Bind columns to appropriate variables
  3. Fetch a record
  4. Update the variables bound to record fields
  5. DBPutRecord
  6. Restart from 3. until end
  7. DBDeactivateSQL
(3,814 Views)
Here is a code snippet that searches the database for a record.  the record (2) does not exist so I want to add a new record using the provided serial number (2).  I receive error messages.  see below:
//R_SERIAL is set to 2, no record with serial number 2 in database
Fmt(SQL,"SELECT SERIAL_NUM FROM AIO WHERE SERIAL_NUM = '%s'",R_SERIAL);
hstmt = DBActivateSQL (hdbc, SQL);
resCode = DBBindColChar (hstmt, "SERIAL_NUM", 11, Sn, &Sn_stat, "");
resCode = DBBindColInt (hstmt, "ICT", &ict, &ict_stat);
resCode = DBBindColInt (hstmt, "PROGRAMMING", &pg, &pg_stat);
ct = DBNumberOfRecords(hstmt);
if(ct==0) // no record found
resCode = DBCreateRecord (hstmt);
strcpy(Sn,R_SERIAL);
ict=0;
pg=1;
resCode = DBPutRecord (hstmt); // returns a -10
(3,807 Views)
I added an INSERT sql statement after update the variables and it appears to work.  using the put record command gave me an error.  Thank you for your help!
(3,805 Views)
I'm happy you found a way to solve your problem. Just out of curiosity, have you tried using DBCreateRecord before DBPutRecord as stated in the documentation?
(3,801 Views)
