LabWindows/CVI
SQL v205 & CVI5.5 & W2000SP2
i've been working with SQL v205, CVI5.5 and WNT 4.0 Wks and everything was OK with databases (dBase).
Now I have the SAME but Windows 2000 Pro with SP2 and databases are not well read. I have a data of '9600' on a record and the program now reads '96'. Every right end ceros are missing on an integer record. Any idea??? Thank you very much in advance.
(3,258 Views)
I am not exactly sure what would cause this issue. I searched through our internal support site, and did not find any information of customer cases that matched this behavior. It doesn't sound like you have made any changes or modifications to the CVI side of things. It sounds like an issue with the OS. You might look at http://www.microsoft.com/sql/downloads/default.asp to see if you could download an update that would fix the issue.
Daniel McChane
Application Engineer
(3,258 Views)
