LabWindows/CVI
help with ping
I asked a question about ping before and got great results from the community here. I have another problem though. I need to be able to see if the ping answers have been reordered, renumbered, etc. Also, if the checksums match. I know that this info is avaiable in the unix version of ping. It doesn't seem to be anything that is returned in the normal results of ping, or in the ping status in the SDK. That is ping, under Windows 2000 (what I'm using).
Can anyone help me???
many thanks,
Lorrie Smith
lorrie.smith@itt.com
(3,548 Views)
Hi Lorrie,
There's something I seem to remember in the Windows 2000 resource kit - http://www.amazon.com/exec/obidos/ASIN/1572318082/ref=ase_ntregistrandtips/002-2628514-3551233
about an improved ping (PathPing) but I'm not entirely sure about what it does give (not running W2k so never bought it) It might be worth an investigate - I'm pretty sure you're not going to get anymore information out of the ping utility that's built into Windows.
The best page I've found as a starting point for Ping is at
http://www.ping127001.com/pingpage.htm
which is well worth a scroll down to the bottom of the page to see a set of links to lots of downloads for Ping utilities.
It's also worth going onto the search engines, and seeing what's available for free too -
There's
an extended console based ping called fping (from http://www.kwakkelflap.com) which can be downloaded here
http://www.sofotex.com/cgi-bin/ls/page.cgi?p=download&d=1&ID=5297
which has extra functionality for
-s : data_size in bytes up to 65500
-c : continuous ping (higher priority than -n)
to see statistics and continue - type Control-Break;
to stop - type Control-C.
-t : time between 2 pings in ms up to 5000
-w : timeout in ms to wait for each reply
-n : number of echo requests to send
-h : number of hops (TTL: 1 to 128)
-v : Type Of Service (0 to 255)
-r : record route (1 to 9 routes)
-a : resolve addresses to hostnames
-f : set Don't Fragment flag in packet
-b : beep on every successful reply (- to beep on timeout)
-i : use ICMP dll instead of raw socket (disables -r)
-l : limit the output to ping results and errors
Hope that gets you started.
S.
// it takes almost no time to rate an answer Smiley Wink
(3,548 Views)
