LabWindows/CVI
Scanning a string from a file
I am trying to scan a string ("Exception") from a big log file and put it in to an array of characters. Is there any way I can scan the entire file and get that particular string (i.e. "Exception") out of the file using the Scanfile or any other function. I was unable to find a modifier in the Scanfile function that serves the purpose. Are there any suggestions?
Thank you in advance.
(3,230 Views)
One way to do this is to open the file and repeatedly call ReadLine() then FindPattern() (both from the CVI Formatting and I/O library).
See the attached file.
Message Edited by cdk52 on 08-04-2006 10:47 AM
(3,224 Views)
