LabWindows/CVI
X axis on on a stripchart
hello,
I would like to plot in real time the position Y versus X of a point on a stripchart ... Do you think that this is possible ? Because I haven't found how to do this ? I know there is graphXY but I don't manage having real time with it ....
thanks in advance
estelle
(3,728 Views)
Call PlotStripChartPoint() for ploting a single point on a strip chart control.  Is that what you are looking for?
If you are trying to do this on a graph control you can use PlotPoint() and PlotLine()
Message Edited by mvr on 08-02-2006 02:42 PM
(3,724 Views)
In fact I would like to plot continously the Y position of a point in fonction the X position of the same point ....in fact plotting the coordinates of the point to see  its evolution ....
estelle
(3,720 Views)
Those should be the right function calls then.
PlotStripChartPoint() will work on a strip chart control.  You would use this if the x axis interval is constant.
If the X axis interval is changing you can use a graph control  amd PlotPoint().  If you want to connect the points with a line use PlotLine().
(3,702 Views)
Thanks for your help
estelle
(3,693 Views)
