LabWindows/CVI
Scripting a 2017 CVI Build
I have a couple of programs I wrote using CVI 2017 and I need to document the build process. I'd like to make it as easy as possible by scripting the build of both projects "a la make".
Is it possible to do such a thing with CVI 2017.
Thanks!
-martin
Martin Blandon
martin.blandon@gmail.com
(2,853 Views)
Accepted by linux_dude
Hey Martin,
You can use the CVI Command Line Interface to script the build process. It won't use a traditional makefile, but you can create any number of build configurations and choose which to use when you build using your script.
Cheers,
Ryan Curtis
Product Support Engineer
Automated Test Software R&D
(2,824 Views)
