Search elements in .INI file
Good afternoon,
Firstly, I am working with INI files and Excel files. In fact, all my elements of my several INI files are also written in a single Excel File like this :
First INI FIle
Tag Name      |     Value     |     Section Name
Seconde INI File
The aim of my application is to refresh the values of the INI files using an Excel file.
At the moment, I have also written all my tag names and section names in my program.c and I compare evrey element of my Excel file with all the arrays that contains tag name and sections name in program.c
I was wondering if, in CVI 8.5.1, there were any function that can tell me that the Sectionname + Tagname exists in the file i am looking at. If there is, I wouldn't have to store all my datas in many arrays.
In fact, I would like to compare my datas directly with my INI file, and not with arrays.
I hope I was relatively clear in what I was searching for.
Thanks by advance.
Vincent Keresztes
(3,838 Views)
Yes and no.
Provided that you are going to use the inifile functions located in the toolslib library you can use the command
Ini_NumberOfItems (, "");
However, the ini files generated and read by these functions have a slightly different structure...
Have a look at the example ini.prj.
(3,834 Views)
Accepted by vincentk
I finally find my solution.
I used Ini_ItemExists, which provide me the information I wanted.
Thank you for helping me !
(3,828 Views)
