LabWindows/CVI
See DebugPrintf output in distribution kit?
Hi All,
Is it possible to select to see the DebugPrintf output when creating a distribution kit?
Thanks in advance!
(3,002 Views)
Hi Turbometrologist,
It's a little unclear whether you want to see the DbugPrintf output during or after distribution creation. I'm interpreting this as question regarding a debuggable executable. In any case, I have listed a couple of links below that might answer your question.
http://digital.ni.com/public.nsf/allkb/7D4CFA73F431FFC88625662B004E7861?OpenDocument
https://decibel.ni.com/content/docs/DOC-1478
I hope this helps.
Josh L.
(2,986 Views)
