LabWindows/CVI
cross product
I could not find in the advanced analysis library the Cross Product function.
There is an Outer Product function but it does not deliver a result consistant with the Cross Product of 2 vectors.
Is the Cross Product function missing or is it under an other name?
Bertrand
(3,320 Views)
Indeed, I’ve made some research and there is apparently no function dedicated to the calculation of a cross product in LabWindows CVI, whereas one exists in LabVIEW.
You have several options though to realize this: Create a DLL (like a LabVIEW DLL) coming from another programming language which includes the cross product functionality. Make the calculus yourself inside of a subroutine. Or create an appropriate matrix and then use the “determinant” function for matrix – with a carefully selected matrix, it should give you something corresponding to the cross product.
I hope this information helps.
Guillaume H.
National Instruments France
(3,308 Views)
Thank you for your answer.
In fact I made a subroutine to calculate the complex cross product I needed in my application but it would be nice to have it in a future release of CVI
Best regards
Bertrand
(3,303 Views)
