SetCtrlAttribute doesn't update ATTR_LABEL_TEXT
I am calling SetCtrlAttribute(handle, ATTR_LABEL_TEXT, graphcontrolID, "arbitrary text"), but the text label on the graph control isn't getting updated.  I tried calling ProcessDrawEvents(), but that doesn't help.  How do I get the label to change?
(5,607 Views)
the sequence of parameters is wrong in your example, it should read: SetCtrlAttribute ( panel_handle, control_id, ATTR_LABEL_TEXT, "label text" );
(5,604 Views)
Should be:
SetCtrlAttribute (panelHandle, PANEL_CONTROL, ATTR_LABEL_TEXT,  "arbitrary text");
(5,603 Views)
Accepted by gstemp
Hi shpanda,
This is the definition of SetCtrlAttribute:
int SetCtrlAttribute (int panelHandle, int controlID, int controlAttribute, ...);
for example
SetCtrlAttribute (panelHandle, PANEL_Control, ATTR_LABEL_TEXT, "text");
It seems that you have first the controlAttribute than your controlID, try to change the other in this way:
SetCtrlAttribute(panelhandle, PANEL_graphcontrolID, ATTR_LABEL_TEXT, "arbitrary text")
Also make sure that the name of handle corresponds to the name of your panel.
Jaime Peña
National Instruments Mexico
Ingeniería de Aplicaciones
www.ni.com/soporte
(5,601 Views)
Oops.  Thank you.  Just a typo.  That was easy!
(5,595 Views)
SetCtrlAttribute()can't change the control value and display it immediately, when you use the SetCtrlAttribute function, the control will be updated after the dispaly function called, so if you want to chang a control value and display it immediately,you can use the SetCtrVal, this function can implement, but it will take a little long time.
GOOD LUCK
(5,511 Views)
