LabWindows/CVI
SetDir Problem
I am having a problem with SetDir as well as SetCurrentDirectory (windows API).
If I use GetProjectDir to get the current project directory and append a lower folder \\DAT\ to it  everything works fine (ie the path changes).
The problem occurs when I try to change the directory from that point forward.
Moving up the tree does not seem to work as well as setting SetDir to GetDir.
(4,269 Views)
Here is my example. The path does not move up the tree.
#include "windows.h"
#include <ansi_c.h>
#include <userint.h>
#include <utility.h>
#include <formatio.h>
#include <cvirte.h>
char origpath[MAX_PATHNAME_LEN];
char newpath[MAX_PATHNAME_LEN];
int result;
int main (int argc, char *argv[])
 if (InitCVIRTE (0, argv, 0) == 0)
  return -1;    /* out of memory */
 //LW SetDir/GetDir example
 //Get project directory
 result = GetProjectDir (origpath);
 printf("\nGetProjectDir Result=%d",result);
 //Setup newpath to <projectdir>\DAT
 Fmt(newpath,"%s<%s%s",origpath,"\\DAT\\");
 result = SetDir(newpath);
 printf("\nSetDir Result=%d",result);
 DirSelectPopup ("", "Select Directory", 1, 1, newpath);
 //Set back to <projectdir>
 result=SetDir(origpath);
 //Setup newpath to <projectdir>\TST
 Fmt(newpath,"%s<%s%s",origpath,"\\TST\\");
 result=SetDir(newpath);
 //end example 1
 //Windows API SetCurrentDirectory example
 result = SetCurrentDirectory(newpath);
 printf("\nSetCurrentDirectory Result=%d",result);
 result=SetCurrentDirectory(origpath);
 result=SetCurrentDirectory(newpath);
 //end example 2
 return 0;
(4,254 Views)
Accepted by ChetK
ChetK,
I looked at the code you posted and saw that the set directories are actually working as expected. The problem is with how you were testing them. The DirSelectPopup documentation says that if Default Directory is "" then it will use the current working directory. This is not always true. The first time you call any of the directory or file selection popups, if this parameter is empty, then it will use the current working directory. If the popup has been displayed before, then it will use the last directory navigated to in the previous use of a popup. That explains why your DAT directory kept showing up in the popups.
This is desired behavior for a functions to avoid a user having to renavigate to a directory with each popup, but our help documentation for this is incorrect. I have filed a bug report for this and the help should be fixed in the next release.
If you would like to display the current working directory in the popup, you will need to specify the Default Directory as such:
        result = GetCurrentDirectory(MAX_PATHNAME_LEN, currentPath);
	DirSelectPopup (currentPath, "Select Directory", 1, 1, newpath)
(4,243 Views)
Thank you,
Spoiler
Spoiler
Smiley Wink
-Chet
(4,236 Views)
