LabWindows/CVI
Setting NI_MinimumBufferSize
Is it possible to set the NI_MinimumBuffersize out of a CVI-Program?
I've seen that its possible with LabView but
I didn't find any documentation if it is possible out of LabWindows/CVI.
(3,436 Views)
Not familiar with that, but I think that that may be a constant (unless it is LV only), but when you say 'out of a CVI-Program' do you mean outside (not using CVI) or out of (using) a CVI prog.
(3,422 Views)
I meant out of / using a cvi program...
(3,404 Views)
