LabWindows/CVI
Setting attribute on menu bar items
How do you grey out an item on a menu  bar ?
How Do change the default values on pannel after you went through it once ?
(3,969 Views)
HI jsugrim,
You can set the Dimmed attribute for the menu bar.  For example, suppose you had a menu bar with the constant name MENU, an item called Item1 and a child item of Item1 called Child. Then to dim Child, you could say
hmenubar = GetPanelMenuBar (panelHandle);      // Getting handle to menubar
SetMenuBarAttribute (hmenubar, MENU_Item1_Child, ATTR_DIMMED, 1);    // Setting the dimmed attribute.
As to your second question, I am not sure what exactly you are asking. If you wanted to programmatically set a control's default value, you would need to set the Default Value attribute like this:
SetCtrlAttribute (panelHandle, PANEL_MyControl, ATTR_DFLT_VALUE, 2);
If I didn't answer your second question, let me know.
Best Regards,
Jonathan N.
(3,962 Views)
I'm not sure if there is a single function call to restore all controls to their default values as set in the UIR file.  (I presume this is the meaning of the second part of your question.)
The way I would do it is in your main program or Init function, read all the values from the controls(GetCtrlVal() ), store theses values, and then when you want to return to the defaults, reset them yourself (SetCtrlVal() ).
(3,955 Views)
Hi jsugrim,
to manipulate menu items there is a useful instruction that is InstallMenuDimmerCallback which has been discussed in CVI Tips / Trick thread: you can look at that thread for some comment on it.
Regarding the default values, it's not clear if you want to change the default value for some control or to return controls to their default value: in the first case you can follow Jonathan suggestion, while in the second case you can use DefaultPanel or DefaultCtrl functions.
I also want to point you to two useful functions wich are SavePanelState and RecallPaneState: they permits you to save on disk actual values of all controls in a panel and restore them afterwards.
(3,944 Views)
Thank you
All of the solutions works very well.
Thanks again,
Jsugrim
(3,934 Views)
