ShObjIdl.h "Empty declaration" warning with CVI 9.0
Just installed CVI 9.0 and now my project generates an "Empty declaration" warning in ShObjIdl.h at line 1330
I'm including shlobj.h to support the use of SHGetFolderPath(), and shlobj.h in turn includes ShObjIdl.h
I believe I have the same compiler options as before with 8.5.1.  I note there is a new SDK version with CVI 9 which likely factors into the explanation.
Is this any cause for concern?
--Ian
Message 1 of 8
(5,868 Views)
I confirmed that the warning does show up because of the following:
typedef enum tagSHCONTF
    ... // actual values omitted for brevity
The typedef is an empty declaration because it does not actually declare any new typename. You're correct that this is new to the updated SDK shipped in CVI 9.0. The previous version of shlobj.h did not include ShObjIdl.h. I confirmed that the same typename ommission exists in the ShObjIdl.h installed by the Windows SDK provided by Microsoft.
I do not see any reason to worry about this warning.
Mert A.
Message 2 of 8
(5,848 Views)
Thanks, Mert.
If you have any clever ideas on how to suppress just this warning (better than inserting a bogus typename into that read-only file), I'd appreciate it. I'd rather not see this every time I compile.
--Ian
Message 3 of 8
(5,820 Views)
Honestly, your best bet is probably to just temporarily make that file writable and throw some new typename after that enum.
But I do have another suggestion that allows you to leave the file alone. You can create a #define that essentially removes the typedef from the enum tagSHCONTF declaration by attributing it to a new, preceeding dummy enum declaration:
typedef enum shcontf_dummy { shcontf_dummy } shcontf_dummy_typedef; enum tagSHCONTF
#include <shlobj.h>
After the replacement, this becomes:
enum tagSHCONTF
If you go this route, you'll have to add this to each source file that you include shlobj.h from.
Mert A.
Message 4 of 8
(5,807 Views)
I added the line
(copy/paste from your post) just before the
#include <shlobj.h>
but now I have some compilation errors
  • "cvidef.h"(201,17) Unknown enumeration 'tagSHCONTF'
  • "cvidef.h"(201,35) Invalid use of 'struct'
Where is my mistake?
Using CVI 2009
Vix
Using LV from 7
Using LW/CVI from 6.0
Message 5 of 8
(5,381 Views)
Accepted by Ian.W
Whoops. It looks like I made a copy/paste error in that post, and Ian never called me out on it. As I said, you have to add a #define, not a typedef:
#define tagSHCONTF shcontf_dummy { shcontf_dummy } shcontf_dummy_typedef; enum tagSHCONTF
#include <shlobj.h>
Sorry about that.
Mert A.
Message 6 of 8
(5,365 Views)
Thanks a lot.
Vix
Using LV from 7
Message 7 of 8
(5,345 Views)
"Ian never called me out on it" .... guilty as charged! Time pressure forced me to hack that read-only file and I never posted back. Thanks, Vix (& Mert!) for bringing this thread to a proper conclusion.
--Ian
Message 8 of 8
(5,335 Views)
