LabWindows/CVI
Showing structure elements while editing code
If you noticed CVI7.0 has this feature where it will show structure
elements when you press a . or -> after the strcuture name or pointer to
structure, respectively. I think it is called "Completion" of some sort.
Anyways, it works for cases where I have 1 structure but not when I have
array of structures. Here is an example.
typedef struct __EMP
char Name[20];
int Age;
} EMP;
Now if I have
EMP me;
and when I type me. all structure elemets show up. But if I have:
EMP BunchOfEmps[10];
and try BunchOfEmp[0]. I don't see elements of EMP structure. If I type:
BunchOfEmp. here CVI shows elements of EMP structure.
vishi
(2,960 Views)
Vishi,
Thanks for reporting this issue; I'll make sure our R&D engineers know about this seemingly buggy behavior.
Azucena
NI
(2,960 Views)
