LabWindows/CVI
cannot get correct polarity from input
I running an Analog scan of all of my 16 channels on a PCI-6025E card. The card is set up for Non-Referenced Single ended, and 10v bipolar. When I start up my scan, aquire all of the points I want, scale the data (using DAQ_VScale) I find that the data is 5v bipolar. I have tried calling the AI_Configure function to make sure that the card is truly in 10v bipolar before I start my scan, but that has no effect.
(3,594 Views)
Telsenbroich,
Does your data appear to be scaled correctly, with an upper-limit of 5V, or does it appear to be scaled incorrectly? What value are you specifying for the gain input parameter of the DAQ_VScale function? If you are seeing an upper-limit of 5V for your data, your gain value may be incorrect.
Spencer S.
(3,594 Views)
Thank you for your response.
Yes, my readings do appear correct. The gain value for DAQ_VScale is 1. I am getting +-10V using MAX, but I just cannot get my porgram to see +-10V. I have had the same problem with some of the example programs as well.
(3,594 Views)
You will need to specify a gain value of -1. This corresponds to the actual gain of 0.5 used for the +/-10V range.
Spencer S.
(3,594 Views)
