Sizeof bit field struct unaffected by pragma pack
I'm trying to use a bit field as part of a larger structure to map out some data returned by another device.  I'm using the #pragma pack(1) command to ensure that no padding is added to the structure.  However, it appears that the bit field structure adds padding anyway.  Consider this exmaple:
    #pragma pack(push, 1)
    struct BIT_FIELD
        unsigned int Bits: 8;
    struct CHAR
        unsigned char Char;
    int x = sizeof(struct BIT_FIELD);
    int y = sizeof(struct CHAR);
In this example x is 4 and y is 1.  I would expect X to be 1.  Is this a bug?  Is there a work around?
(4,200 Views)
I suppose the reason is that you are mapping bits in an unsigned int: try using an unsigned char instead.
(4,181 Views)
I hadn't thought of that.  The ISO standard says that bit fields have to be declared as "unisgned int", "signed int", or "int".  Nonetheless, that worked!  Thanks!
(4,179 Views)
