Smart camera target
Hello!
I have tried to sort out of the abundance of information whether it is possible to install necessary software (CVI RT runtime, etc) to NI 17xx cameras to program then with CVI?
At this time I have installed only the recommended software to the target and fail to see any CVI runtimes in the installation wizard. The CVI environment reports that I must have the correct version of Labwindows CVI Run-Time Engine for RT installed.
Thank you!
(3,751 Views)
Accepted by Juurma
You cannot install a LabWindows/CVI RTE on an NI 17xx smart camera.  If you read the user manual you can only install the software below to the smart camera target.
NI 17xx Smart Camera User Manual
If you wish to develop in LabWindows/CVI you will first need to make a VBAI script to deploy to the target.  Then you can make calls to the smart camera using the VBAI C API.
Isaac S.
(3,735 Views)
Isaac S.,
Thank you for clarifying that. I can not believe I did not get it from the GS-guide myself.
Kind regards,
Mart Juurma
(3,729 Views)
