Software trigger
Background:
I am writing C code and calling the DAQmx API directly.  I am developing in VS community 2017 with the latest DAQmx.  I am using the Synch AI-AO example with success.  I changed the examples triggering scheme to have the AO task trigger the AI task with success. I have a PXIe chassis with a PCIe-6358 board.
Question:
I want to trigger the AO task from a DAQmx function call, a software event is going to start the AO/AI in one-shot mode.  I tried DAQmxSendSoftwareTrigger() with no success.  Is this idea even possible?
Ed
(3,060 Views)
Does anyone know how to setup DAQmx to use a software trigger (DAQmxSendSoftwareTrigger())? I have been trying to use DAQmxCfgDigEdgeAdvTrig(taskHandle, "Dev1/PFI8", DAQmx_Val_Rising) to setup my PCIe-6320, but I get this error:
DAQmx Error: Specified property is not supported by the device or is not applicable to the task.
Property: DAQmx_AdvTrig_Type
Task Name:
Status Code: -200452
The only two options for triggerEdge are: DAQmx_Val_Rising and DAQmx_Val_Falling.
I am usig ANSI C, does anyone have an example of how to do this?
(1,040 Views)
The documentation for this function says something about a switch task!
https://www.ni.com/docs/en-US/bundle/ni-daqmx-c-api-ref/page/daqmxcfunc/daqmxcfgdigedgeadvtrig.html
This property is about NI-Switch hardware advancing to the next channel on the configured trigger signal.
You probably want to use DAQmxCfgDigEdgeStartTrig() instead. Your hardware only supports digital triggers as seen here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIhASAU
Rolf Kalbermatter  My Blog
(979 Views)
