LabWindows/CVI
Spline Interpolation failes because of "undistinct" data
Hi all!
I have the following problem:
I measure an distribution density and calculate corresponding cumulative distribution function of the measured data. Now I need to know some specific x-values, for example where is the CDF at 50%. To do that, I tried to interpolate the CDF with SpInterp() with interchanged X and Y-arrays. Befor I can use SpInterp() I need to calculate the second derivatives with Spline(). But Spline() gives me allways a runtime error, because the x-values must be distinct. I get the same problem with PolyInterp(). RatInterp() works, but gives sometimes very bad results, so it's not usable in this case.
Has anyone an idea?
Thomas
(5,019 Views)
Hi!
you measure a distribution density, so I figure the x-value are distinct, the y values are not. You get that problem by interchanging the arrays.
So, I suggest you don ´t do that.
If you look for the x-value for y=Y0 for instance:
Take your y-values and subract Y0, you get a zero crossing at for Values around Y0. Intergrate and you get a local maximum/minimum. That should be easy to detect.
Regards
René
(4,964 Views)
Hi René,
good idea. I will try it out and compare it with my current solution.
I solved it this way: I interpolate the sum distribution to increase the resolution by 100. Then I can easily step through my array and find my y-values with sufficient accuracy.
Thomas
(4,955 Views)
