LabWindows/CVI
[stripchart] get rid of the marks of the y-axis
Is it possible to disable the marks of the y-axis? Or if not to get some space between the marks and the labels/numbers?
I´m asking because I have to use the right y-axis and there people always mistake the marks for a minus and think that the stripchart does show negative values.
(4,691 Views)
Accepted by topic author ISITEC_RIEPER
You can using label strings and format the numbers with leading spaces.
(4,688 Views)
Thanks, that will do it, I just have to figure out how to do it right 😉
(4,672 Views)
